Steady-State AC Response of RL Circuits
TheBloke
Joined May 23, 2014
2
Wondering if anyone can help me out with determining expression for the resistor voltage and inductor voltage, with an AC input 5V (RMS) ??
Any help is much appreciated:)
TheBloke
Joined May 23, 2014
2
Yes in Series
Thanks for the reply, I have used the equations you have provided, and I am trying to plot the magnitude of the voltage VR and VL against the frequency, however, even though the source is 5v (RMS) I am seeing answers as high as 50V......
Any idea?
Thanks
shteii01
Joined Feb 19, 2010
4,644
If they are in series, it is just a voltage divider.
Replace inductor with its impedance, now you have a voltage divider formed by two "resistors":
Vresistor=5[R/(R+Zinductor)]
Vinductor=5[Zinductor/(R+Zinductor)]
As you can see the denominator is always larger than nominator. So you will always have a number smaller than 1 in the square brackets. Then you multiply this number by 5 and you will have result that is smaller than 5.
Example.
Let us say that you have:
R=1 kOhm
Zinductor= 100j
V= 5 V
Then:
Vresistor=5[1k/(1k+100j)]=4.95-0.495j
|Vresistor|=4.975 V
Vinductor=5[100j/(1k+100j)]=0.0495+0.495j
|Vinductor|=0.497 V
Also note that increasing the frequency will increase denominator even more. So there is no way for you to exceed 5 volts.
33,186
Yes in Series
Any idea?
Thanks
It would help if you showed your work. Otherwise you are expecting use to be mind readers (i.e., guess), when if you simply showed your work we could determine where you are going wrong. Doesn't that sound like a better approach?
