I'm working on a small project which is nearly completed, I have 100 white LEDs and 100 colour change LEDs wired to a modified ATX power supply. I was going to switch this supply on using a normal throw switch to connect the pwon/pwgrnd (green/grey) wires but I have found a switch that I would like to use instead on the RS website here :
www.rswww.com
then enter :
665-641
as the part number to search for.
It is a piezo actuated pushbutton switch which is momentary. Does anyone have a simple circuit I can use with this switch to turn the PSU on and off ?
regards
Malc
www.rswww.com
then enter :
665-641
regards
Malc
