Star grounding
Audioguru again
Joined Oct 21, 2019
6,826
The obsolete Mosfets are connected wrong.
The 2SJ162are upside down and they should be on the bottom of the circuit as common drain, not common source.
The 2SK1058 should be at the top of the circuit as common drain, not as common source.
I did not check the phasing.
Audioguru again
Joined Oct 21, 2019
6,826
What a coincidence.
I worked for a company that was the Canadian distributor for NEC large modern business telephone systems.
Suddenly the warehouse became empty and sales became zero. I asked my boss if his company was going bankrupt and he did not answer so I resigned. A few years later I read that he sued NEC for breaking his contract and he won 7 million dollars!
NEC spun off its semiconductor business to Renesas company who sell and make obsolete transistors, and NEC has withdrawn from manufacturing most things.
Ian0
Joined Aug 7, 2020
13,131
The phasing is correct. The non-inverting input of the long-tailed pairs drive a buffered, cascoded VAS, which in turn drives a complementary feedback pair output stage with TR21/Tr20/TR24 on the positive supply, and TR21/TR19/TR23 on the negative supply. The MOSFETs should indeed be common source. It has 2-pole compensation.
The 2SJ162s are upside down, but they are correctly on the positive supply. The 2SK1058s are drawn correctly.
The lateral MOSFET is still alive and well, and now made by Exicon and distributed by Profusion. ECX10P20 and ECX10N20 are similar to 2SJ162 and 2SK1058.
38,504
The purpose of a star ground is to keep the ground currents from the higher power stages going through the ground for the input/low power stages to get to the supply return.
So you follow the ground currents and pick the point for the star ground accordingly.
nikolopikolo
Joined Sep 17, 2020
33
So it seems fine the way I designed it using common source. I actually switched around the SJ162 on the PCB its just a schematics that is faulty. Could it be that one of these MOSFETs is not working properly just simply conducting to the output?
Ian0
Joined Aug 7, 2020
13,131
Possibly - but you can easily tell - it's gate-source voltage will be zero. If it's gate-source voltage is >2V or so, then the circuitry is switching it on.
Audioguru again
Joined Oct 21, 2019
6,826
Here is a similar old amplifier circuit from Elliot Sound Products using the same Mosfets as in this thread but they are used as normal common drain followers.
It was designed and tested in 2004 with an update in 2012. 180W into 8 ohms.
OOPS, it has a copyright that says No Copies Allowed. It his project #101. He will not provide a parts list, he says for you to buy his pcb instead.
nikolopikolo
Joined Sep 17, 2020
33
His design looks very similar indeed, but my source tested the circuit I'm using and he implemented a common source follower. Many designs do implement a common drain follower, but this one is designed differently.
Ian0
Joined Aug 7, 2020
13,131
It looks like it has been lifted out of the International Rectifier application note and a current mirror added. IR's circuit doesn't blow up.
Audioguru again
Joined Oct 21, 2019
6,826
A Cmos low power opamp uses common source amplifiers at its output so that its output is "rail-to-rail". Because its output Mosfets have voltage gain then the gain is reduced when loaded.
Class-AB amplifiers using bipolar transistors have output transistors that are always common collector emitter-followers, never common emitter amplifiers because they would be very difficult or impossible to bias with stability.
You said "common source follower" that is wrong, it is a common source amplifier, not follower.
Ian0
Joined Aug 7, 2020
13,131
Nonsense - there are loads of complementary feedback pair amplifiers, where the output transistors are common emitter. They are not particularly difficult to bias.
