Stall torque vs full load torque
Man10
Joined Jul 31, 2018
199
I have a mabuchi 555 motor. The full load torque is 380 g-cm. The stall torque is 1,360 g-cm. Does this mean max torque is 1,360 g-cm?
LowQCab
Joined Nov 6, 2012
5,101
NO !!!
If the Motor is operated at more than 380 g/cm,
the Motor will eventually start to OVERHEAT,
and is very likely to fail.
"Stall-Torque" is the amount of Torque generated when the Rotor is completely STOPPED.
This is more commonly referred to as "Locked-Rotor", and is not a very useful number unless
the Motor will have to get a very-Heavy-Inertia-Load up-to-speed,
and therefore,
the Motor may spend a significant amount of time in a hazardous, over-loaded, condition.
To avoid these conditions, it is a good idea to use an Electronic-Motor-Controller
which can control, and/or, limit, the Current being supplied to the Motor.
A more useful specification-number is "Locked-Rotor-Amps",
which is how much Current the Motor will demand at "Stall" speed.
This number is good to know when designing an Electronic-Controller for the Motor
which must be able to withstand the "Maximum-Locked-Rotor-Amps".
