I have recently had a crank-mounted cycling power meter go pop when I experimented with using a LIR2032 instead of a CR2032 battery. I figured there would be some sort of voltage regulation going on in there... and it seemed to be working normally for around 5 minutes.
After getting to the circuit board, there was an obvious blown SMD component, which I desoldered and, hey presto, it works again!
I really want to identify the blown component so that I can decide whether I need to replace it or possibly upgrade them so that I can use the LIR2032 batteries. I'm also interested in whether there is some form of voltage regulation on the board. I think its a triple layer board, making following the tracks a bit tricky...
currently I'm thinking the popped component might be a tantalum capacitor of some sort, but I haven't found a manufacturer with components that look exactly like that and the codes seem to vary a bit between manufacturers. Also, could that be an LDO regulator directly beneath it?
many thanks
Dan
many thanks
Dan
