Ý
The resistor does not fit in the centre anyway, i could have pilfered a bigger one from the charger i stripped out but thought this would be adequate,
Removed IC4 tonight as it smoked everytime i powered the amp up, the new IC3 and IC4 are in the post, do i need to do any testing before replacing these ? ,
I plan to install some IC sockets and replace only IC4 to start with,
Also now i have both thermal LEDs on, these were on before i removed IC4
Seriously?You will need MUCH BIGGER heat sink than that to dissipate 150 watts.
Les.
