That would not be a pleasant experience during a performance if a bulb blows in one fixture - everything, including the sound, would go off.The Lighting Fixture is not designed to be Powered with no Bulbs installed.
The problem is definitely inside the fixture. I disconnected the load side of the mains input EMI/RFI filter, and it didn't trip the RCD, so the filter, line cord, and power switch are ok.I am starting with the assumption that your ballast and lamp socket are mounted to a metal enclosure- let me know is this is incorrect.
I would remove the easiest of the socket and the ballast from the luminaire first. If that doesn’t solve the problem remove the next part ( the switch). If you remove all of the electrical parts and still have the problem,remove the linecord.
With any luck that will get you there.
After taking most of it apart, looking for tell-tale evidence of anything wrong, I've put it all back together, and it's working fine - no tripping.Let us know what you find...
I didn't find anything untoward, no exposed wire ends, no "trapped" wires, everything appeared to be in good order. I've replaced all the cable ties I had cut off to dismantle it.To trip the RCD it must have had spurious earth leakage somewhere. I can't see that being a poor earth connection. Perhaps a termination where an exposed piece of wire, or a strand of a wire, brushing a piece of the frame.
It seems that you have tidied up whatever was causing the problem.
Well it's behaving itself now on test.I switch it off from time to time, let the lamp cool, and turn it back on - still no tripping.Good work, however it worked! The main think is that the problem is solved, at least for now.
For an RCD breaker to trip there needs to be leakage, usually from the Line but also possibly from Neutral to earth.
Correcting the ground connection is is good for safety and maybe sporatic leakage from something to ground was the reason for the tripping.
