SSD1306 OLED dual rail supply
Audiloj
Joined Oct 17, 2018
Hi.
I´m using an OLED display in one of my designs. I´ve been using it without the internal charge pump because of noise. So change pump is no option!
Now I´ve made changed to the design, and I no longer have sufficient voltage to use it without the charge pump (VCC = 7-15V).
But I do have a dual rail: +/-5V supply.
Normally OLEDs are supplied with dual rail, and I suppose the charge pump is generating a negative supply rather than boosting the positive volatge.
Have anyone tried to supply these OLED modules with with dual rail supply for the LED driver (VCC and VLSS)?
ArakelTheDragon
Joined Nov 18, 2016
1,366
Hi.
I have not tried, I do not know anything about them.
I think they are powered only by positive voltage supply. If you do not want to use the charge pump, then an equivalent of it without the noise would be a good idea. You can try some IC that boosts the voltage for you.
Audiloj
Joined Oct 17, 2018
Of course I could add more to the circuit. But I do not want to add a boost because it´s a high impedance high gain circuit. And of course I want to keep the bom as low as possible. And since normaly OLED display have dual supply LED drives I was hoping this could be a neet solution.
I´ll do a test my self as soon as I get time.
