After breadboarding a square wave oscillator according to the attached circuit diagram, I measured it at slightly over 11 kHz at 2.5 V peak to peak. If I do the frequency calculation with R3 = 1k and C1 = 35nF(measured) 11 kHz is about right.
I don't understand the operation of the circuit. Suppose that at some point in time C1 is discharged and the output just went high, C1 will now charge through R3 until the voltage at B is higher than the voltage at A (4.5 V). Now the output goes low and starts to drain C1. Pretty much immediately the voltage at B will be lower than the voltage at A and the output will go high again, oscillation occurring at infinite Hz. But it doesn't. Why not?
Looking at the functional block diagram on page 9, I think for logical low output pin 1 sinks current to the potential on pin 4. For logical high the output transistor is cut off and a pull-up resistor pulls the output up, to 9 V in my case. So where does the current come from that charges C1? It can't be through the pull-up resistor because it would change the frequency by a lot.
Why am I only seeing 2.5 V peak to peak and not 9 V? I'm not sure if my scope is 1M or 2M ohm input impedance, but with my 10M ohm multimeter I see the same voltage. I'm not seeing the attenuator if there is one.
