Square wave in for a sine wave device : Harmful ??
ranatungawk
Joined Oct 30, 2008
226
Is it harmful, If I supply 230V, 50Hz "square wave" power-input to a electronic device with SMPS (Such as TV,PC.. originally designed for 230V, 50Hz ) ? Or due to the SMPS wont it be a big problem ?
dl324
Joined Mar 30, 2015
18,376
Hi Ranatungawk,
It really depends on how the transformer, assuming it has one, will respond to the higher order harmonics.
tcmtech
Joined Nov 4, 2013
2,867
In general very few SMPS based device are all that fussy about what sort of input power they get and will work anywhere from DC to several hundred Hz AC as long as the supply voltage is below their rated maximum voltage even if they are listed to use 50 - 60 Hz power.
dl324
Joined Mar 30, 2015
18,376
It's more about how the transformer will deal with higher frequencies. Power transformers are low frequency. Higher frequencies could cause humming, best case, or transformer failure in the worst case.
tcmtech
Joined Nov 4, 2013
2,867
Where does the OP mention anything about a transformer? You do know what a SMPS is right? o_O
dl324
Joined Mar 30, 2015
18,376
Designed my first switching regulator about 40 years ago. That was long before you could buy a switching regulator IC that gave you examples of buck/boost applications, so you needed to understand the theory...
Most equipment has a transformer that steps line voltage down to some reasonable level so you don't have to use caps and rectifiers rated at hundreds of volts. If said equipment didn't have a step down transformer, discussing it on this forum would be disallowed. Read between the lines...
tcmtech
Joined Nov 4, 2013
2,867
I only read what is posted and the OP only mentioned SMPS's. It saves me from a lot of unnecessary speculation and pointless debate over unknowns that likely do not exist or are not a presently relevant concern to the OP. :rolleyes:
The OP never mentioned iron core 50 - 60 HZ transformer based power supplies. Only SMPS which by design convert the incoming power to a HV DC making its initial incoming form and frequency largely irrelevant.
If I were to speculate on what he did say I would take that when he mentions ' If I supply 230V, 50Hz "square wave" power , is likely the power being supplied by a cheap power inverter to which effect most typical SMPS's are unaffected by.
dl324
Joined Mar 30, 2015
18,376
Hi tcmtech,
He mentioned TV and PC which usually have step down transformers. Sometimes people don't articulate their questions clearly, either because English isn't their first language or they're not a trained engineer. Instead of jumping to conclusions or giving answers that would be wrong if one took the time to ask clarifying questions, it's better to make sure you know what question you're answering.
And we know we're not allowed to discuss equipment that connects to line voltage without using a transformer. The OP was talking about supplying line voltage to something that contained a SMPS. If the SMPS didn't use a step down transformer, we should know that so we don't violate Forum policy and help him do something dangerous.
32,933
@tcmtech : That last remark really was uncalled for.
Most TV/PC and similar SMPS have a transformer in them. The transformer is designed to work with a much higher frequency which is provided by the switching mechanism at the front end on the primary side which uses feedback from the secondary side. Discussing the potential effect of harmonics on this circuitry seems quite reasonable.
Jony130
Joined Feb 17, 2009
5,598
But do not forget that every off-line smps has a bridge rectifier and 400V bulk capacitor at the input. So who cares if the input voltage is a sine wave or square wave?
Reloadron
Joined Jan 15, 2015
7,892
Papabravo said:
It depends on the device and each one is different. Some might work, but no doubt others will be compromised.
That would be my thinking. Devices like my home computer and my TV as well as cordless telephones have no problems at all with power from UPS units which output a "Modified Sine Wave" which pretty much looks like a square wave. :) Some devices with linear power supplies using some transformers may not care for the square wave or modified sine wave input. So in a simple nutshell it all comes down to the device. Some will and some won't. Never gave it much thought but some of my power tools that are mains operated (120 VAC 60Hz) may not operate well on a square wave and I am not about to try the microwave oven. :)
Ron
Roderick Young
Joined Feb 22, 2015
408
I don't know about TV's. I know for sure that PC's today use line switching power supplies, and the first thing that they do is rectify the line voltage into high voltage DC. They will work fine off a square wave, modified sine, or even high voltage DC *. Every brick-type computer supply I've seen is the same way, as are the tiny, light phone chargers. Only the older "wall wort" adapters actually have a line transformer in them, and you can usually tell those simply by their heavier weight for their size.
I have heard, but have not personally verified, that AC motors will not run well off a square wave - that they can overheat, draw more power than expected, or even burn out.
* With the exception that if the supply uses discrete rectifiers for a full wave bridge, only two of the parts will carry the current, and could over heat if the supply is pushed to the extreme limit.
12,164
Many off-line switching power supplies have power factor correcting front ends, and these care very much about the shape of the input voltage waveform. In this type of supply the bulk capacitor comes after the boost converter stage. The boost converter is relatively complex, as it shapes the input current to track the input voltage while maintaining a constant output voltage. The control loop bandwidth is not wide enough to handle the fast edge of a square wave.
Loke almost everyone has said, it depends on the device - for more reasons that you might think.
ranatungawk
Joined Oct 30, 2008
226
Thanks!! Mr. Young!!! It's a very clear answer for my question.
I don't know if i'm correct, but as I think, with in a SMPS , AC power (Sine or square wave) goes to a bridge rectifier and then it is converted to DC as the first step. Even though the input is Sine or square it wont be a matter for other stages after the bridge rectifier of the SMPS..
**** as i have seen some of AC motors wont run with a square wave at all!!! when AC with square wave is supplied, it gives a hum (Drrrrrrr....)and fan blades begins to vibrate but rotate.
