Square Wave Generator Construction
ifiaxxy
Joined Jun 5, 2014
10
hi, I am building a circuit with op-amp to generate a square wave. The circuit diagram is shown here: http://hyperphysics.phy-astr.gsu.edu/hbase/electronic/square.html#c4
The op-amp I use is TL074 and when I run it, there is a problem: I get the square wave in the first few minutes (like 20min or so) and then the output becomes a constant voltage. All my resistors are 10k and my capacitor is 4.7uF.
Can anyone help me fix this problem? I want the circuit to generate the square wave constantly for up to 12hr.
Thank you!
Bernard
Joined Aug 7, 2008
5,784
Seems like there should be a R3 from + supply to + input. Difficult to discharge C to below ground when discharge path is ground or near ground.
Veracohr
Joined Jan 3, 2011
783
The oscillation runs fine for about 20 minutes, then stops? Maybe it's the JFET-input opamp latching up. Do you have a different opamp model you can try?
ifiaxxy
Joined Jun 5, 2014
10
This is the only op-amp I've got... I think the op-amp is still working though, because when I unplug the power supply and put it back on, it works again
ifiaxxy
Joined Jun 5, 2014
10
And "ground" is at 0V, right? In other words, you haven't confused V- and ground?
Is there a load on Vout that might be causing the op-amp to overheat and shut down?
GND is 0V and when I run the circuit, the op-amp doesn't get hot, so I guess there's no overload
18,184
OK, just wanted to check the "obvious" stuff.
How about putting a 0.1µF decoupling cap on the op-amp's power pins? Maybe it's falling into an oscillation of some kind.
ifiaxxy
Joined Jun 5, 2014
10
for a decoupling capacitor, do you mean that I can simply connect Vcc+ and Vcc- with a capacitor?
to3metalcan
Joined Jul 20, 2014
263
Run a cap from each power pin to ground...reduces the chances of hf oscillation swamping out your square wave. Also, tell us about your main timing cap. What value? What type? Have you tried swapping it for another?
to3metalcan
Joined Jul 20, 2014
263
I'm guessing your 4.7uF is electrolytic...they're not always great for oscillators. If bypassing doesn't help, try increasing the value of R and using a smaller C...a value you can get as a film or ceramic.
