I am New to Program... Interrupt not occur and also always LCD display shows "out of Range" i am using PIC16F723A
Moderators note : used code tags
C:
#define _XTAL_FREQ 16000000
#define RS RC0
#define EN RC1
#define D4 RC2
#define D5 RC3
#define D6 RC4
#define D7 RC5
#include <xc.h>
#include "lcd.h"
//BEGIN CONFIG
#pragma config FOSC = HS
#pragma config WDTE = OFF
#pragma config PWRTE = ON // Power-up Timer Enable bit (PWRT enabled)
#pragma config BOREN = ON // Brown-out Reset Enable bit (BOR enabled)
#pragma config CP = OFF // Flash Program Memory Code Protection bit (Code protection off)
//END CONFIG
long int a=0;
void __interrupt () freq()
if(INTCONbits.RBIF == 1)
INTCONbits.RBIE = 0; // Disable the port change interrupt
if(RB4==1)
T1CONbits.TMR1ON = 1;
if(RB4==0)
T1CONbits.TMR1ON = 0; // Stop timer1
a = ((TMR1H<<8)|TMR1L);
TMR1H = 0;
TMR1L = 0;
INTCONbits.RBIE = 1; // Enable the port change interrupt
INTCONbits.RBIF = 0;
void main()
TRISB =0b00010000; //RB4 as Input PIN
TRISC =0x00; //LCD Pins as Output
//PORTB = 0xFF;
//ANSELB=0x00;
INTCONbits.GIE = 1; //Global Interrupt Enable
INTCONbits.RBIF = 0; //Clear PORTB On-Change Interrupt Flag
INTCONbits.RBIE = 1; //Enable PORTB On-Change Interrupt
Lcd_Init();
Lcd_Clear();
Lcd_Set_Cursor(1,1);
Lcd_Write_String("Current");
Lcd_Set_Cursor(2,1);
Lcd_Write_String("Measurement");
__delay_ms(3000);
Lcd_Clear();
T1CON = 0x10; //Initialize Timer Module
while(1)
TMR1H = 0; //Sets the Initial Value of Timer
TMR1L = 0; //Sets the Initial Value of Timer
if(a>=1)
Lcd_Clear();
Lcd_Write_String("Frq = ");
Lcd_Set_Cursor(1,12);
Lcd_Write_Char(a);
Lcd_Set_Cursor(1,15);
Lcd_Write_String("Hz");
else
Lcd_Clear();
Lcd_Write_String("Out of Range");
__delay_ms(500);
