I would like to program an AT89LP6440. It has an SPI interface described here: http://www.atmel.com/Images/doc3593.pdf Is it possible to program the chip with only an FTDI cable?
Someone recommended I look into avrdude but I have not found support. It seems that it might be possible with a different driver since the cable has 4 data lines which is what SPI needs.
If it is the simple matter of converting the data sent out over the FTDI cable into SPI with clock signals, I can do this easily with a microcontroller. Building anything more complicated than that might be beyond my abilities.
