SPI interface of Atmel SAM W25 Xplained Pro
Papabravo
Joined Feb 24, 2006
22,111
I dived into it, but the SPI rate is too high... cannot interface between them.
Hold your horses. There is no need to run the SPI interface at the maximum rate. The actual data rate is determined by the master device which generates the CLK signal. The peripheral device MUST operate at the rate determined by the SPI bus master. The peripheral might have a maximum rate that it can operate at and the SPI bus master must respect that. In most cases a peripheral device will not have such a limitation.
dorYairi
Joined Oct 24, 2019
Thanks, but the ADC will not sample in the max frequency, which is essential for my project
