If the motor is a DC brushed motor, addition of a resistor is going to cause a problem.Used a 9 vdc supply and added 7 ohm resister to the circuit. I intend to use a manual three position rotary switch to vary the speed in increments
The motor itself will be used to wind thread using various sizes of spools The blades have been removed and replaced with an applied spindle. Thanx, Ed.
The advantage of gears is that as you gear the speed down you get a corresponding increase in torque.i wud suggest gears.
why not make a mechanical switch (double entendre )?
Good suggestion, lightingman.Just use an LM317, adjustable regulator..... I do that on my dimmers, using a thermistor instead of a pot/pre-set....Daniel.
