Yes; cone movement - not position.No, it is not significantly different for this application.
The coil generates a voltage when the voice coil moves in the magnetic field, which is the same as the cone movement,
Knowing the movement you can derive the position.Yes; cone movement - not position.
I guess that's why hard drives used to have a track 00 sense opto-interruptor, many early speech coil head positioners had a glass quadrant with an index scale etched on it - AFAIK: the modern ones use a "servo-write" one side of a platter entirely devoted to index code that tells the CPU where the heads are.Knowing the movement you can derive the position.
