Hi All
I'm having a dilemna at the moment, I have designned a battery balancing circuit and need connector for this that are rated at 10A max per contact perivously I used a SAMTEC IPBT connector which met my requirement the only problem was the height with the connector and the mating half had a height that was a lot greater than the height of the mechanical enclosure this PCB is going into. Can anyone please help me with this. The connector needs to be specifically surface mount, and needs to come to height of 20mm with mating half included (goes to cables). I was thinking even right angled connectors would be suitable.
Kind Regards
Art
Kind Regards
Art
