hi all,
a few questions on impedances...
1. i know load/source terminations is necessary to prevent signal distortions at either end due to reflections for high speed signals... the best way will be to have both source and load terminations for impedance matching. How about DC signals? is impedance matching necessary?
2. How do we easily measure our load impedance or source impedance? by their typical operating voltage and their typical current drawn? what if we do not have these info, what is a quick way?
3. for a load, is the input impedance refering to the load impedance? similarly, output impedance = source impedance?
4. assume a scenario where we have 2 ICs (IC_1 and IC_2). Pin 1 of IC_1 is output and connected to pin 2 of IC_2 (input) via a discrete circuitry with parts like resistors and caps... therefore, its like we have IC_1 connected to a discrete circuitry (of resistors, caps) and in turn this discrete circuitry connected to IC_2.
Do we match IC_1_pin1 impedance to IC_2_pin2 impedance straight?
or
We match IC_1_pin1 to discrete circuitry input and then match discrete circuitry output to IC_2_pin2?
or
The discrete circuitry can actually act as a impedance matching network for IC_1 and IC_2?
Thanks for your patience!!!!
or
or
