Hello. I want to build this sound card oscilloscope: https://makezine.com/projects/sound-card-oscilloscope/
However my sound card has 1.3V inputs and the circuit in the example is made to limit the voltage to the soundcard to 0.7V (because most soundcard inputs are 0.7V).
I want to modify the circuit to allow more voltage. Can anyone suggest what components I can use to replace the diodes? The original uses 1N4148 which is a common switching diode.
I'm an electronics newbie and I'm assuming that the switching diodes in the schematic allow voltage to pass between the + and - side if the voltage goes over 0.7V. I could very well be wrong and that is the reason I ask here before making the circuit because I don't want to blow something up or start a fire. If I'm correct I need to find diodes that pass 1.3V in stead of the 0.7V.
Thanks in advance for any help.
