Sound barrier in a liquid.
MvGulik
Joined Nov 3, 2011
41
Mmm. ... That made me wounder a bit about this to. So looked around, and found this:
It might be theoretically possible, but I don't think the sound barrier in water would be as significant. In air it was such a problem because the compression ahead of the aircraft made a "wall" of extra dense air. In water, the differences in density would be very small (water is essentially incompressible). Also, water is much more viscous than air, so it's likely not possible to reach the speed of sound due to all that friction.
source: www.sciforums.com (post: #8/8)
THE_RB
Joined Feb 11, 2008
5,438
Nobody watches the science channels? They have been working on supersonic underwater missiles for some time using rocket engines and some type of nose cavitation device that generates some gas pocket effect at the nose and back over the skin of the underwater missile.
Blofeld
Joined Feb 21, 2010
83
This is an incredible clever trick, but it is "only" aimed at reducing the friction drag and thus achieving very high speeds by means of supercavitation (basically the effect you described). The body does not reach supersonic speeds (which would be around 1500 m/s in water).
http://en.wikipedia.org/wiki/Supercavitation
By the way, it is even possible to reach a speed in water that is higher than the speed of light in water. The only catch: You have to be an electron or some similar little critter.
http://en.wikipedia.org/wiki/Cherenkov_radiation
THE_RB
Joined Feb 11, 2008
5,438
OK, it's not "supersonic" as such, but it does overcome the issues of travelling at high speeds underwater. To make it supersonic just requires a higher powered rocket engine, just like in air... ;)
killivolt
Joined Jan 10, 2010
836
I've thought about this a couple times in my life. If you could charge the water around the object or missile with "Ultra High Voltage, High Frequency" at the very tip, creating like charges around the skin of the missile.
Like the skin effect on high voltage wire, the water would be repelled creating your pocket and therefor being viscous the "Super Charged air or water around the object it might act as a Magnetic / hydraulic pressure adding to stability and speed.
Sometimes I shouldn't be allowed to type, after drinking the night before:)
strantor
Joined Oct 3, 2010
6,875
My mostly uninformed hypothesis is that it would be impossible. It is possible in air because air is compressible. You can push through it faster than it can push through itself. But water is incompressible, so you could not possibly move the molecules out of the way faster than they can could naturally displace themselves, as in a sound wave.
Unless you were a subatomic particle which could actually travel in the space between the water molecules.
Thoughts?
killivolt
Joined Jan 10, 2010
836
Thoughts?
That makes sense, I just found that if I hold the HV cathode above water I can dimple the surface tension, so I thought maybe it was feasible to Electrically defuse the Molecules making it permeable or stretchy.
thatoneguy
Joined Feb 19, 2009
6,359
The effect would be none, voltage with reference to what? Adding a charge to the entire body of water is a choice, but impossible in the open ocean.
Something like coating a boat in a hydrophobic substance, which actively "repels" water, like Teflon, doesn't give much of a boost, especially when the inevitable crud build up starts.
Image of Dew Drop on hydrophobic leaf from wiki
THE_RB
Joined Feb 11, 2008
5,438
The "it" I was referring to was the research model underwater missile which already had the necessary features (ie nose cavitation design) which allowed the missile to travel in a cavitation pocket in the water. I believe *given enough engine power* it would be supersonic.
I was not saying you could just stick a huge engine on *anything* and make it travel supersonic underwater. ;)
Brownout
Joined Jan 10, 2012
2,390
My post had a typo that changed the meaning. I was trying to say that "in air" the aircraft required a complete redesign to break the sound barrier. They tried using more power on existing designs, but couldn't break the barrier. Only a complete redesign of the airframe made the efforts successful.
