Hi, guys!
Does anybody know the value of these capacitors on Sony PS4 slim PSU ADP-160ER AAA: C18 and C19. I've circled them in the image (they are missing in the photo.)
One of the 2 mosfets was blown (they are right next to the caps and removed in the photo, Q4 was burnt), so I replaced it and transferred C18 and C19 caps from a known working PSU (aftermarket replica) and the problem was fixed, 12V output and all good.
A user from a tech forum said that these caps C18 and C19 act as filters, so there really is no difference which ones I solder back on. So I've replaced them with some random caps with the same package from factor from a HDD mainboard. Now I did that, turning on the known good supply caused the exact same mosfet to burn.... I am not sure which other components might be damaged, too. There was a pop and the 12V line is not working... So - I would greatly appreciate it if somebody has the values of C18 and C19 so that I can get my test PSU working again :/ Thanks!!!
