Some thing strange about OLED
LAOADAM
Joined Nov 21, 2018
956
The OLED seems quite easy to wiring and use, but frequently met that the OLED works well in one code, doesn't work for another one, works well in one circuit, doesn't work for another one.
any suggestions to make it stable?
Adam
28,132
AND pleae explain what you mean by "in one code", that is not a term that I am familiar with. Organic LEDs are different and so the forward voltage to current relations are different as well.
LAOADAM
Joined Nov 21, 2018
956
Thanks.
The 'code' here I mean a 'program' that uploaded, should I call it a sketch?
KeithWalker
Joined Jul 10, 2017
3,615
The two examples that you quote are for two different OLEDs having different display resolutions. Your OLED will only work with the correct one.
28,132
Thanks.
Code is much more descriptive than "sketch" , and now it has become clear to me that the quetion is about the operation of an ORGANIC LED DISPLAY device, not simply an OLED by itself. That i an entirey different topic.
