some problems about the buck circuit
anstxfw
Joined Sep 14, 2016
5
hi,all.The buck circuit using half-bridge will burned after power on if no pwm in.Two MOSs and IR2103 burned.But if there is 100khz 50% pwm ,the circuit can work normally. If no pwm in,HIN and LIN are high level,the bootstrap capacitor can not charge. So i think no MOS can be on. However,the fact is my circuit is burned.Sadness.
shortbus
Joined Sep 30, 2009
10,050
Look at your circuit again. You have the same input on both the Hin and Lin at the same time, this causes what is called 'shoot through' it is what is causing the mosfets to "burned". They can't be on at the same time. Google"shoot through".
shortbus
Joined Sep 30, 2009
10,050
That should be ok in theory, because Hin is active high and Lin is active low. In practice, the inbuilt 560nS dead-time may be inadequate for FETs with a high Cgs value.
I was to fast to answer I guess, didn't look at the data sheet for the mosfet driver. Most of the ones I'm familiar with have both of the inputs as a high when active.
