Some help with Java threads
geekoftheweek
Joined Oct 6, 2013
1,429
At the moment the code below is giving me exceptions for networking in the main thread. I've compared it to a previous app that this is going to replace and I can't see where I went wrong (maybe just need to take a break and uncross my eyes). Another thing I would like to do is create a thread class in a separate file to help clean up the main class a little. I had things working on different levels over the last few days, but never fully what I wanted.
Code:
package com.flipperbuilt.trailerlights3;
import androidx.appcompat.app.AppCompatActivity;
import android.os.Bundle;
import android.os.Handler;
import android.os.Looper;
import android.os.Message;
import android.util.Log;
import android.view.Menu;
import android.view.MenuInflater;
import android.view.MenuItem;
import android.widget.Toast;
import java.io.IOException;
import java.io.InputStream;
import java.io.OutputStream;
import java.net.InetSocketAddress;
import java.net.Socket;
public class MainActivity extends AppCompatActivity {
    @Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_main);
        main_message_handler = new Handler(Looper.getMainLooper()) {
            public void handleMessage(Message msg) {
                Bundle bundle_in = msg.getData();
                Message message;
                if (bundle_in.getString("exception why").length() > 0) {
                    Toast toast = Toast.makeText(getApplicationContext(),bundle_in.getString("exception where")+"\n"+bundle_in.getString("exception why"),Toast.LENGTH_LONG);
                    toast.show();
        new socket_thread_class().start();
    @Override
    public boolean onCreateOptionsMenu(Menu menu) {
        MenuInflater inflater = getMenuInflater();
        inflater.inflate(R.menu.app_menu, menu);
        return true;
    @Override
    public boolean onPrepareOptionsMenu (Menu menu) {
        return true;
    @Override
    public boolean onOptionsItemSelected(MenuItem item) {
        switch (item.getItemId()) {
            case R.id.menu_disable_switches:
                connect();
                break;
        return true;
    private void connect() {
        Log.e("MainActivity","connecting");
        Message msg = thread_message_handler.obtainMessage();
        msg.arg1 = SOCKET_CONNECT;
        Bundle b = new Bundle();
        b.putString("ip","192.168.1.31");
        b.putInt("port",5010);
        msg.setData(b);
        thread_message_handler.dispatchMessage(msg);
    class socket_thread_class extends Thread {
        @Override
        public void run() {
            keep_running = true;
            this.setName(socket_thread_class.class.getName());
            this.setPriority(android.os.Process.THREAD_PRIORITY_BACKGROUND);
            Looper.prepare();
            thread_message_handler = new Handler(new Handler.Callback() {
                public boolean handleMessage(Message msg) {
                    Message message = main_message_handler.obtainMessage();
                    Bundle bundle_out = new Bundle();
                    message.setData(bundle_out);
                    switch(msg.arg1) {
                        case SOCKET_CONNECT: {
                            Log.e("SocketThread", "socketConnect() -- IP -> " + bundle_in.getString("ip") + ":" + bundle_in.getInt("port"));
                            try {
                                out_socket = new Socket();
                                out_socket.connect(new InetSocketAddress(bundle_in.getString("ip"), bundle_in.getInt("port")), 2000);
                            } catch (Exception e) {
                                bundle_out.putString("exception why", e.toString());
                                bundle_out.putString("exception where","connect()");
                            } finally {
                                if (out_socket.isConnected()) {
                                    Log.e("SocketThread", "socket good");
                                    try {
                                        //bundle_out.putCharSequence("LastCommand","getOutputStream()");
                                        stream_out = out_socket.getOutputStream();
                                    } catch (IOException e) {
                                        bundle_out.putString("exception where","getOutputStream()");
                                    try {
                                        stream_in = out_socket.getInputStream();
                                        bundle_out.putString("exception where","getInputStream()");
                        break;
                        case SOCKET_DISCONNECT: {
                            Log.e("SocketThread", "DISCONNECT");
                            keep_running = false;
                        break;
                    main_message_handler.dispatchMessage(message);
                    return true;
                private Socket out_socket;
                private OutputStream stream_out;
                private InputStream stream_in;
            if (keep_running) Looper.loop();
            Log.e("SocketThread","at the end");
        private boolean keep_running;
    private Handler main_message_handler;
    private Handler thread_message_handler;
    private final int SOCKET_CONNECT = 1;
    private final int SOCKET_DISCONNECT = 2;
