Some common circuit board design issues 1
David Su
Joined May 9, 2019
1. As figure, similar to this kind of copper-to-PAD distance is only 2.5 mil. and it's easy to cause a short circuit, so it should be adjusted to 8 mil or more.
2. The character height in the file is only 0.5MM and many are not enlarged. The number is too short to be printed. Normal word height requires 0.8mm.
3. The copper is displaced, causing a short circuit. This information is suspected to be short-circuited in many places. It needs to be confirmed with the client how to make it.
4. V-CUT to the line requires a safety distance of 0.3MM, the zero-pitch design is suggested to move.
5. The disconnection needs to be connected.
6. As shown in the figure, the disconnection needs to be connected.
7. BGA should be at least 4mil from the line, at least 4mil for the clip, and 10mil for the minimum diameter of the BGA. Please correct it.
bertus
Joined Apr 5, 2008
23,003
The images are not shown.
Please upload the images using the "Uplad a File" button below the reply window.
Bertus
