Solving systems of differential equations - from Kirchhoff's law
Motanache
Joined Mar 2, 2015
652
For this circuit we write equations and we obtain a system of equations.
How to solve that system of equations ?
The circuit from below Figure,
The signal generator provides exponential form.
The current through Radd is required.
Any answer, or any suggestion are welcome.
But wish no offense for other members of the discussion.
33,221
In order to solve the system of equations, you first have to obtain the system of equations to be solved. Have you done this? If so, what did you get?
Then you can solve them using any valid technique to solve a system of differential equations and there are several. For the systems of equations that result from the analysis of linear systems, the use of Laplace transforms and very common and powerful.
Motanache
Joined Mar 2, 2015
652
Motanache
Joined Mar 2, 2015
652
http://en.wikipedia.org/wiki/RLC_circuit
Another question?
How they achieved bandwidth (implicitly Q Factor)?
It can be mathematically demonstrate the bandwidth?
Why the bandwidth (through Q Factor) depend on reactive power divided by active power?
When I think of bandwidth, I imagine the voltage function FFT.
