Solving for the frequency
simo_x
Joined Dec 23, 2010
200
Hi all,
I'm in doubt on how to solve for the \(\omega\) for any transfer function \(T(\omega)\), and I would like to solve it.
My question is not related to 1st order functions, but from 2nd order and so on.
For example, suppose I have a simple RLC low pass filter:
Solving for the transfer function :
\begin{align}
T(s) &= {1 \over s^2LC + sRC + 1}\\
s &= \text j \omega \\
T(\text j \omega) &= {1 \over 1-\omega^2LC + \text {j} \omega R C}\\
|T(\text j \omega)| &= {1 \over \sqrt{(1-\omega^2 L C)^2 - (\omega RC)^2}}
\end{align}
for example, I tried to solve for the -3dB frequency
\(0.707 = |T(\text j \omega)|\)
But I cannot find the correct result, and I know by simulation and from the first pole that \(f_c \approx 16\) kHz
I opened this post here because I think my doubt is more related with math concepts.
Thank you in advance.
simo_x
Joined Dec 23, 2010
200
Hi Mike,
It's the second one, but you swapped the values of inductance and capacitance between them.
L = 10 uH
C = 10 nF
From the denominator of the transfer function I know that in this case the frequency of -3dB is 15931 Hz, and for the circuits you posted the -3 dB is 15,915 Hz for the LP and Hp.
But I would like to know how to solve the equation analytically, if possible.
Thanks !
22,084
To solve for ω you would:
  1. Substitute the values for R, L, and C.
  2. Square both sides of the equation to remove the radical
  3. Then solve for ω
  4. Check your work by using the value of ω to get a magnitude of 0.707
simo_x
Joined Dec 23, 2010
200
That's what I have done solving a 4th order polynomial:
\(0.707^2 \left ( \left ( 1 - \omega^2\cdot10^{-6}\cdot10^{-9}\right )^2- \left (\omega \cdot 1000\cdot 10^{-9}\right )^2 \right ) -1 = 0\)
but I cannot get the correct result, or I cannot recognize it...
22,084
If you expand things out you have terms in the fourth, second, and 0th power of ω. That suggests a quadratic polynomial in ω^2 which can be solved with an appropriate substitution.
32,974
It really helps if you show your work from beginning to end. Think about it -- you say that you believe the problem you are having is related to math concepts -- so wouldn't the most effective way for people to spot where you are having problems with the math for you to show the math you are doing?
simo_x
Joined Dec 23, 2010
200
Hi, sorry for my late response. I had to study other things too..
This is the calculation I have done:
\begin{align}
& 0.707 = {1 \over \sqrt{(1 - \omega^2LC)^2 + (\text j \omega RC)^2}}\\
& 0.707^2 = {1 \over [(1 - \omega^2LC)^2 - (\omega RC)^2}]\\
& 0.707^2((1 - \omega^2LC)^2 - (\omega RC)^2) = 1\\
& 0.707^2(1 - 2\omega^2LC + \omega^4L^2C^2 - \omega^2R^2C^2) -1 = 0\\
& 0.49985 - 0.99970\omega^2LC + 0.49985\omega^4L^2C^2 - 0.49985\omega^2R^2C^2 - 1 = 0\\
& 0.49985\omega^4L^2C^2 - \omega^2(0.99970LC + 0.49985R^2C^2) -0.50015 = 0\\
& -1.0010\cdot 10^8\\
& 1.0010\cdot 10^8 \\
& -7.2858\cdot 10^{-17} + 9.9930^4\text j\\
& -7.2858\cdot 10^{-17} - 9.9930^4\text j\\
\end{align}
But no one brings me to the result of 100100 rad/s..
32,974
Note that your 0.707 comes from 1/sqrt(2). Leverage that knowledge.
\begin{align}
& \frac{1}{\sqrt{2}} = {1 \over \sqrt{(1 - \omega^2LC)^2 + (\text j \omega RC)^2}}\\
& \frac{1}{\sqrt{2}}^2 = {1 \over [(1 - \omega^2LC)^2 - (\omega RC)^2]}\\
& \frac{1}{2}[(1 - \omega^2LC)^2 - (\omega RC)^2] = 1\\
& (1 - \omega^2LC)^2 - (\omega RC)^2 = 2\\
& (1 - \omega^2LC)^2 - (\omega RC)^2 - 2 = 0\\
& 1 - (2LC)\omega^2 + (LC)^2\omega^4 - (RC)^2\omega^2 - 2 = 0\\
& [(LC)^2]\omega^4 + [(2LC) - (RC)^2]\omega^2 + [-1] = 0\\
\end{align}
Now apply the quadratic formula and see what happens.
simo_x
Joined Dec 23, 2010
200
Yes ! I got it !
\begin{align}
\begin{cases}
-1.0374\cdot 10^{-15} + \text i1.0010\cdot 10^{5}\\
-1.0374\cdot 10^{-15} - \text i1.0010\cdot 10^{5}\\
\end{cases}& \text{1st pole}\Rightarrow \approx 15.9\,\text{kHz}\\
\begin{cases}
-9.9900\cdot 10^{7}\\
\end{cases}& \text{2nd pole}\Rightarrow \approx 15.9\,\text{MHz}
\end{align}\)
Thank you for your help.
I will be more careful with my calculus next time !
