Solving for the Average Power and the Reactive Power
omarsinnno
Joined Feb 5, 2019
8
In the following exercise they asked to find the average power of the 5 ohm resistor, then the average power of the 8 ohm resistor, and then deduce the the voltage source (rms) value.
Given
: -2j capacitor absorbs -2.3 VARs.
I did the first part and found out that the average power of the 5 ohm resistor is 0.9199 W by finding that the Vrms = 3.033150178 V.
I haven't successfully used the information given or deduced so far to find the average power in the 8 Ohm resistor.
Any help is really appreciated!
33,309
It's the same as the total current in the circuit.
Think about that statement for a moment. That junction has four branches, so what does it even mean to say that it's the same as a specific current?
What does KCL say about the current at that node?
omarsinnno
Joined Feb 5, 2019
8
The sum of all currents at that node should be equal to zero. In other words, the current entering the node is equal to the one leaving.
33,309
Okay. So can you define all of the currents entering and leaving that node and set up an equation that applies that constraint?
Next, what can you say about the voltage across some of the components relative to the others?
You could also approach this from the opposite direction. Simply solve the entire circuit in terms of Vs, including the power in each component. The use the known power in the capacitor to find Vs and use Vs to answer the rest of the questions.
Even better practice would be to solve for all of the requested quantities in terms of the power in the capacitor and then plug that known power into each one in turn.
The Electrician
Joined Oct 9, 2007
2,986
This "Vrms" you refer to, is it the voltage (with respect to the "minus" terminal of Vs) at the node where the 8 ohm and 5 ohm resistors are connected? Please show how you determined this value.
omarsinnno
Joined Feb 5, 2019
8
Knowing that in a capacitor P = 0, then the reactive factor is equal to 1 giving us:
(Vm.Im)/2 = 2.3
Im = Vm/Z
We then get Vm^2 = 9.2, giving me the answer I eventually got to for Vm.
L General Electronics Chat 1
V Homework Help 8
