I recently picked up an old promotional radio made by Wurth.
I knew it wasn't working when I bought it but i liked the look of it and thought it would look good on my work bench. The more I thought about it, though, the more I wanted to get it working so I managed to open the case and extract the guts.
My knowledge of electronics is pretty basic but from what I can see, there is nothing obviously wrong with it. No visible damage to components, solder joints look good enough (I reflowed a few suspect looking ones to be sure) and the off/vol switch is passing full battery voltage on the switch side of things, but when you switch it on all you get is a very brief crackle from the speaker and then silence. Not even static.
The radio is based on a TDA1083 chip so I guess that could be faulty, I downloaded a data sheet for it but figuring this all out seems beyond my abilities for now. I've attached a bunch of photos so you can see what I'm blabbering on about.
Anyone got any suggestions where I might start looking?
