(SOLVED) how to trigger a relay when voltage drops to zero ?
cmartinez
Joined Jan 17, 2007
8,881
But the doorbell is already running at 3.6V when idle, and I strongly suspect that pulling that line up to 12V could be bad for whatever the doorbell is connected to. It sounds to me like it's the equivalent of a microcontroller input with a pull-up resistor holding it high until the button press holds it low. If it's anything like that, 12V would fry it, right?
My bad, I wasn't paying attention. Let me try again and I'll be back. In the meantime, the original circuit can be simplified this way:
R1 is not necesssary for the circuit, but I placed it there so that you can measure the current being drawn to the 3.6V doorbell for both when the circuit is idle and when the button is pushed.
I changed the values of R2 and R3 to minimize that effect. I suggest you play with this circuit a little, and see how adjusting those values has an effect on the current flowing through R1
gutfarah
Joined Jul 24, 2017
18
Thanks for that, but am I right in thinking that this keeps the relay on all the time and only off when the push button is pressed?
