[SOLVED]How component requirements are determined for power supply
Pushkar1
Joined Apr 5, 2021
416
I want to design a power supply to meet the following requirements,
Input Voltage : 12 V AC
Input current : 2 A
Output Voltage : 5 V DC
Output current : 1A DC.
I have seen many circuits on Google in which I see that I need the following components to make the power supply
Rectifier
capacitor filter
Regulator IC
Resistor ( current limiting)
At first need a rectifier in my power supply. There are three types of rectifiers half wave, full wave and bridge rectifier
How do we decide which rectifier required and why it should be used only
Audioguru again
Joined Oct 21, 2019
6,826
Simply learn about the differences (pros and cons) of half-wave vs full-wave then the cost and space of separate diodes vs a bridge rectifier.
A simple calculation shows that the fairly high input voltage causes the regulator to get hot and dissipate about 10W of heat.
Most voltage regulators need an output capacitor.
Pushkar1
Joined Apr 5, 2021
416
Welcome to AAC!
Is this school work?
No, This is not a school assignment
What is the PS used to serve?
Regulated or not?
Regulated , To power 5V Digital IC
I guess Bridge rectifier is more efficient than others, if this is the case,
Then When half wave and full wave rectifier should be used in power supply ?
Pushkar1
Joined Apr 5, 2021
416
Half wave would give up half of the transformer current. Does the secondary have a center tap?
Ohh I am sorry I gave the wrong information in my starting post. I have 12 V DC adapter and I want to convert 12 V DC into 5V DC @ 1 A current.
I understood that I need bridge rectifier IC or four diodes to make bridge rectifier circuit. I would like to use diodes. A lot of ratings diode avillable in the market and I have to choose diode according to my requirements.
When choosing a diode I must remember that it is perfect for my supply and it should not be damaged, Which rating of diode should I choose to make rectifier?
MaxHeadRoom
Joined Jul 18, 2013
30,808
If it is already DC, why do you need a bridge?
There are many all-in-one bridge rectifiers out there of different current ratings, also four 1n4007 would make a 1 amp bridge.
What are you using for a voltage regulator? IC7805?
BobaMosfet
Joined Jul 1, 2009
2,211
Input current : 2 A
Rectifier
capacitor filter
Regulator IC
Welcome to what it means to be an Electronics/Electrical Engineer. This is what we _do_. We take needs and determine the constraints and risk-factors, and then choose components that satisfy those constraints and risk factors.
Start here:
Title: Understanding Basic Electronics, 1st Ed.
Publisher: The American Radio Relay League
ISBN: 0-87259-398-3
djsfantasi
Joined Apr 11, 2010
9,237
If your input and output are DC, then there is no need for any rectifier. A rectifier converts AC to DC.
A 7805 voltage regulator is the simplest solution. The data sheet shows the ancillary components needed - such as input and output capacitors.
dl324
Joined Mar 30, 2015
18,465
For your application, you don't need rectification.
With 12V in and 5V out at 1A, I'd use a switching regulator. Otherwise, you're going to dissipate 7W in the regulator at full load.
