[Solved] help me to get this circuit working. (Auto On-Off Solar Light Rechargeable)
John O'C
Joined Mar 22, 2017
68
Eric
I have just found a boost converter in my 'stock '
MT3608
that should do it?
I was planning to use one 18650 rechargeable battery.
Do I put it at the output of my circuit, just before the LED strip?
ericgibbs
Joined Jan 29, 2010
21,649
hi,
Looking over the circuit the problem is that the 3.7v battery and 5V solar panel use the transistor to select the current source for the LED/Battery Charge, for night/day operation.
E
John O'C
Joined Mar 22, 2017
68
hi,
E
Eric, That is beyond my understanding at this point. That a 'no' then?
ericgibbs
Joined Jan 29, 2010
21,649
hi John,
Checking, I don't see a possible way of using that simple circuit to drive a 12V LED strip, even with a MT3608.
I will give it another look over.
Are you prepared to consider a more complicated circuit build.?
E
John O'C
Joined Mar 22, 2017
68
Eric, I have two 5 m white LED strips warm white/white.
Nowhere does it specify the current required. However, I put them on my power supply and it looks like 150 mA.
By the way, it looks like they both maxed out on brightness on about 9 V, even though they are specified as 12 V.
Thanks again for the help, much appreciated.
John
ericgibbs
Joined Jan 29, 2010
21,649
hi John,
Assuming a 100% eff conversion, down from 12V at 150mA, to a Collector voltage to 5.5V Solar or 3.7V battery means 320mA > 480mA Collector current for the Boost Conv.
The best you can get thru the existing Blue LED is approx 20mA with that circuit.
A different type of circuit is required.
Check thru the web for 12V LED strip drivers.
E
