ACV Range 200 but actually were you going to measure an unknown I would suggest 750 (Highest Range) and if you have a red & black lead the Black in Common and the Red in V right above the Common. Just measure across the outlet large and small slots. The probes should be long enough to make contact and make sure your fingers are clear of the metal of the probes. You check with the GFCI connected and powered up. The outlet I saw you post was a US standard 120 VAC outlet. You should see 120 VAC with the GFCI properly reset. If not you can gently remove the outlet from in the box and measure across the Line side which should be power in.Hi, Ron. The digital multimeter I ordered has finally arrived. It's a DT-830B.
https://images-na.ssl-images-amazon.com/images/I/41Hh8RFPrVL.jpg
To which point should I be setting the dial to check out GFCI assembly?
Ron
