In a room, I have a GFCI AC outlet. It was working just fine. I was curious to learn how much space there was in the cavity that the outlet is in. So I shut off the power to the room by switching it off at the circuit breaker. I then unscrewed the outlet and pulled it out.
I also pressed the Test and Reset buttons on the outlet (while power was both off and on, if I remember correctly).
After turning the room's power on by flicking on the circuit breaker, I noticed that the LED light on the AC outlet is on. But whatever I plug into the AC outlet doesn't work, in either of the two outlets. The devices work, as I've tried them in the outlets of other rooms.
How can I figure out what the problem is? How can I fix this?
Photo album of the outlet: http://imgur.com/a/UBrlo
Thu Aug 10 11:35:35 PDT 2017 update. An electrician apprentice working at Home Depot confirmed that my gfci outlet is dead.
