[SOLVED] Digital combination locks
vhiev
Joined Nov 5, 2023
Jerry-Hat-Trick
Joined Aug 31, 2022
849
Instead of connecting the green LED 470R resistor to ground, connect it to the base of an NPN transistor with the emitter connected to ground. The green LED should still turn on but less brightly. Connect the solenoid between power and the transistor collector. Check that the transistor can handle the current needed by the solenoid
This uses the transistor to switch the higher current you need from the small current into its base
vhiev
Joined Nov 5, 2023
thank you for your answer.
the solenoid is now working after i added the npn transistor into the circuit.
thank you so much!
