solve circuit
solve this
  • 3
    Votes: 0 0.0%
  • 3
    Votes: 0 0.0%
  • Total voters
    0
  • Poll closed .
Jony130
Joined Feb 17, 2009
5,600
LOL "Using the source transformation method find Voin the network given below" = "Using the source transformation method find Vo in the network given below".
And Vo is a voltage across 6k ohms resistor.
33,137
Using the source transformation method find Voin the network given below. Label and draw each step where it required. Write each step of the calculation to get maximum marks and also mention the units of each derived value.
So... what is your question?
You have a poll with two identical options -- sounds like a political push poll. I'm guessing that the results of your poll will be 3.
Now, if you want help with the problem you've given, you need to show YOUR best attempt to solve YOUR homework.
