Solenoid switching coil across Hall effect sensor
mutthunaveen
Joined Jan 9, 2009
Dear Board
i have a coil based hall sensor which will measure currents from 100mA to 600A. this is placed just beside a HV switching coil (12V 1A coil).
this coil will on off the power from a power source and the hall sensor measures HV current flowing towards load.
Im worried if hall sensor placed just 2 cm away from solenoid??
is there any impact i need to study and consider or is it safe??
Thank you
Naveen
Kjeldgaard
Joined Apr 7, 2016
451
If it's a sensor device with the measuring coil on a closed ring core, I do not think there are problems with the short distance.
However, if you provide the part number and your requirements for the measurements, it's easier to provide a useful answer.
