How would I go about re-soldering this component to my PCB with the pads underneath?
Thanks for any advice
Reflow oven...How would I go about re-soldering this component to my PCB with the pads underneath?
You probably have to do both at once - surface tension pulls the pins into alignment if you do it right. If you solder the heat pad and find the pins are out - you're probably up a gum tree without a paddle.Thanks everyone. I can solder the pins my main concern was how to solder the pads underneath and how necessary they are. Based on mcgyvr post above it seems they serve a pretty important role in thermal dissipation
Well no - but they wouldn't bother putting it there if the chip didn't really need it.......................Can I ask a question?
That center pad is nothing more than a heat sink right?
