Hello. I just build the attached schematic. It works only with CA3130. I can't find on the local/internet shop the CA3130 (out of stock).
Then I decided to use 1/2 of LM358 as thermocouple amplifier. I know that it doesn't have the same performance as CA3130. I also added a resistor (1M) from +12V rail to the pin 5 of LM358 (non inverting input), for the protection of the soldering iron if the thermocouple doesn't work properly.
I have a few questions:
1. Is the schematic correct ?
2. Should I connect the 1M resistor from the +12V rail or from the K of the zener diode ?
I know that my shematic doesn't have cold junction compensation, but I used LM358 at a few thermocouple amplifiers for soldering stations and it seems to work, even if it is not perfect.
