Soldering iron
Berzin
Joined Dec 17, 2020
59
Hi guys
Actually I am in a big delima as I am planning to solder my pcb design parts with the pcb with a soldering iron and a 12 volt battery (car battery) and we all know that that a soldering iron will drink electricity like hell to get hot and I don't want my electric bill to go very high so that's why I was thinking that can i attach the soldering iron directly to the battery by alligator clips to the soldering iron so my question is will the soldering iron will work or get hot and secondly am I going to damage any thing this way
35,320
You are more likely to do more harm than good.
Who told you that a soldering iron takes a lot of electricity lied to you.
A soldering iron takes less electricity that what it takes to light your room.
Berzin
Joined Dec 17, 2020
59
Oh so I can do this way which is that I will put it on the invertor which is powered by battery 12 volts
SamR
Joined Mar 19, 2019
5,549
Might want to look at one of these. Very similar to the one I keep in my toolbox. Great when you need to do work outside.
35,320
How are you going to charge the car battery?
It will cost you more to charge the battery from your house mains than if you power the soldering iron directly from the house mains. There is no free lunch unless you use a solar charger. And then you will have to spend a lot more to buy a solar panel than the cost of electricity for many many years.
Show or tell us the make and model of your soldering iron.
The voltage and wattage should be printed on the iron.
Berzin
Joined Dec 17, 2020
59
I am planning to charge my battery directly by my car through jumping wires while I am planning to buy STANLEY 69-031B Round 30-Watt Corded Soldering Iron (Black and Chrome)
35,320
Let's do the math.
Suppose you left the 30W iron on for 24 hours a day.
30W x 24h = 720Wh = 0.72kWh
Assuming the cost of electricity is US$0.08 per kWh,
cost of 0.72kWh = US$0.06 = less than 5 Rupees
If you are going to turn the iron on for 4 hours, cost of electricity is US$0.01, less than 1 Rupee.
