Hey guys I'm new to site
Im having a bit of a problem I removed a faulty charging port from a board with a heat gun however a had to a poly a little force. The problem that I'm having is that when I removed the port the solder or what ever its called were removed also from the board can it be fixed?
I will post a picture picture just in case you guys are not clear about what I'm talking about
