- Joined Jan 23, 2018
- 28,253
I really recommend using a socket for the IC, and soldering the wires to the socket. Also, use thin enough wire either #26 0r #28, to avoid breaking pins off of the socket.
Out of curiosity, why would the moderator remove a link? We have links in many of the posts here to many different things and they are often very helpful.I'm actually getting very interested in the prototype PCB path. It looks pretty cheap.. At least the upfront costs I'm seeing. I can get a set of variations built and take some measurements.
I found (commercial link removed by moderator) and will give that a shot.
Circuit boards do offer advantages BUT they are difficult to modify if you want to change a connection. They are great if you need to make a bunch of copies. But creating a layout takes more than an inexpensive autorouter if you want a really good layout. And as for "cheap", that is relative.Out of curiosity, why would the moderator remove a link? We have links in many of the posts here to many different things and they are often very helpful.
I ordered some and they're in the mail, I just needed them this weekend to solder up 4 dual SOP-8 op-amps, in place of 2 quad SSOP-14 op-amp's.Breakout boards like the ones show in the post above are super helpful in this case. If you insist on just using wires, use a small gauge wire. Using something like 30awg wire will help avoid the solder joints from breaking so easily.
Design with resistor values from the 5% tolerance values chart.Thanks for the tips. It's my first circuit schematic. Sounds like it's looking OK overall.
Noted on the decoupling caps. This will be powered by a 9V battery initially at H1.
The resister values are the tricky part here. I've indicated the ideal measurements but I realize they don't actually exist on the shelf. I'll need to fudge these in assembly. I'm expecting to get 5 or so duplicate circuits on a PCB and then build 5 variations with different resisters. Finally, I'll select the one that fits the curve best.
If the best notch ends up 970Hz or 1088Hz I'll simply adjust the tone generator to match. I'm not expecting to be dead on at 1000Hz... I don't feel that's a reasonable expectation.
