If that's what you paid for just 2 panels someone has ripped you off!! Just be very careful you why your spending any more money.
1500 for 12 panels and inverter and wiring.
They also gave a cool looking scrub.
I understood invertors have a best operating area circuit,3300 watts you referring to is output.
Input can be anything right?
That's dependent on input specs right?
Sorry.
Well after googling i found this. Attache
Ok, you mean inverter itself cannot give more than 3300 watts no matter input.
What i am saying is, That is fine.
80% of times my panels don't give more than 5 amps.
If they exceed, should we not be under -- input range as per specs?
Doing 6 x45 plus 6 x45?
9 amp is written on pannel. Assume its 6. Now is there anything i can do with 2 panels?
Maximum rating is 9 amp.(sticker)
I measured, full washed full sunlight to ne 6.8 amp.
But as experts here said, not taking any chance, or i will fry my inverter.
Will only do if it's sure going to work. Can't experiment, all this is costly.
Yes equator, India.
which varies the load on the panels to keep them at max efficiency.
once they inverter is at max output power,
its two options are to let the voltage on the panels increase, or to turn off.
By the way,Wonderful.
So i am safe. Let me do 9 + 3 parallel
I said this earlier, i am saying again.Wonderful.
Wonderful.
Out of interest,Each panel must pass the same current, up to the maximum any one panel can handle. So paralleling 3 panels will not increase the current overall.
I have two 11 panels in series/parallel and when snow covers them, I have to clean off all 11of any string to get full power for that string. If I leave one panel covered, current is low for the entire string, and power is low as well. My panels have built-in diodes, so two strings of 11 panels will work if only one set if clear (2500W rating), but if I clear both 11 panel strings, I get the 5000W
I have another string of 10 panels, but that has to feed a separate inverter because the voltage is different. You can have multiple inverters, nothing wrong with that concept. In fact, separate inverters help when you have a problem with one string, as the other string still produces some power
No, I have two strings in parallel to the same feed point on the inverter. Yes, the inverter has 2 sets of terminals, but they are the same bus internally. That is just to allow higher current input to the 5kw inverter but keeping the voltage within upper limits. Each string does have, however, a separate fuse. After fuses, they all feed the same point where there is the DC disconnect to the rest of the inverter.Out of interest,
Are your panels really in parallel ?
I have two strings , that go into my invertor,
But the inverter has two different inputs each with the power optimiser circuit.
its like two invertors in one,
I can read back and the two strings most of the time have different voltages on them.
Have look here on shading
https://www.renewableenergyworld.com/storage/shade-happens-installation/#gref
My setup is this.Out of interest,
As others have commented,No, I have two strings in parallel to the same feed point on the inverter. Yes, the inverter has 2 sets of terminals, but they are the same bus internally. That is just to allow higher current input to the 5kw inverter but keeping the voltage within upper limits. Each string does have, however, a separate fuse. After fuses, they all feed the same point where there is the DC disconnect to the rest of the inverter.
Serious envyMy setup is this.
10 panels in series.
45 x 10 = 450 volt dc which i get.
Like batteries, i thought i can do 9 + 3 parallel and inverter will see only 10 panels.
But as andrewmm warned above, i am not doing anything.
My panels are shining in sunlight.as in attachment.
Maybe i will create a small coil and connect and put it in my bathtub..)
What else to do? Its useless..2 panels 500 USD..
My setup is this.
As I said earlier, my panels have built in diodes, to prevent one string from feeding into another. With 2 strings, I can run well with only one uncovered from snow, the other covered. Once I uncover the second string, the power doubles. Inverter has one DC feed after fuses to the actual inverter circuit. But yes, it is a good design to make the panel strings identical if possible.....As others have commented,
putting panels in parallel only works if the efficiency and illumination on both strings is the same,
If there are not two MPP inputs to that inverter, then you can not connect two strings to the inverter.
.Your panels are rated at 335 watts. Your inverter, rated at 3300 watts, can only handle 10 panels. It sounds as if you have purchased two new panels. You can swap two panels out for the new units and you may get a small increase in power.
I am fitting nonetheless, let's measure output and see how it works.The diodes in the panels
there are normally across the panel,
so a panel can not be reverse biased,
If you have one string giving 300 volts,
and the other 200 volts,
the 200 v panels will contribute nothing as they are reverse biased.
Yes,Your panels are rated at 335 watts. Your inverter, rated at 3300 watts, can only handle 10 panels. It sounds as if you have purchased two new panels. You can swap two panels out for the new units and you may get a small increase in power.
