I am trying to come up with a scale-able solar light design.
For my initial project I am going to use some 12v LED strip lights(3 sections, 9 LEDs total). I should preface this with I have very little idea what I am doing. Provided my test was correct these pull .05 amps. Does that sound right? I think that I am looking at about 3.6 Watt/hours. I want this light to come on at night automatically. I am not sure how I want it to shut off but I am leaning towards it shutting off at a set battery voltage to avoid damage to the battery. Does that sound reasonable? I want a minimum run-time of 4-6 hours. I have a 18ah SLA for initial testing but I would like to use something that is more appropriate. I have also have several 18650s that need a project. I would really like to incorporate these.
37°11′42″N 93°17′10″W The solar panel will have a clear view of the south and east sky. There are a lot a cloudy days in the winter. If there is a long cloudy stretch the light can remain off. I am looking at using 3-5 of these 18650s.
I have a few bits that may come in useful for this project. I would like to use these where possible.
Solar Panel 2.5W 5V/500mAh (x2)
Solar Panel 12V 3W
XL6009 DC-DC Booster Power Supply
Max DC-DC XL4005 Step 5A Down Adjustable Power Supply
Boost Buck DC-DC Adjustable Step Up Down Converter XL6009
Smart Electronics 5V Micro USB 1A 18650 Lithium Battery Charging Board With Protection Charger
Various Diods
Various Resistors
Various Capacitors
Photo Resitors
N-Channel MOSFET 60V 30A
P-Channel MOSFET 60V 27A
Voltage Regulator - 12V COM-12766 ROH basic L7812
Arduino Uno
I am still looking a for a nicely done diagram to base this project on, but so far I have been unsuccessful. If someone has something that would get me going in the right direction I would greatly appreciate it.
Solar Panel 12V 3W
Various Diods
Various Resistors
Various Capacitors
Photo Resitors
Arduino Uno
