I have a soldering iron and will be using the 8 pin.1) Have a soldering iron, or access to one? I may have presumed you did.
2) Is the 10F200 a 6 pin sot-23, or an 8 pin DIP?
3) Downloaded MPLAB, and completed the first couple of the Gooligum lessons previously suggested?
4) There are no shortcuts. Until the first led blinky program has been successfully completed, other projects should wait.
5) The 28 pin demo board sent along could do this without a breadboard, just the hookup wire to the servo, and possibly the battery supply if the programmer can't supply 5V.
6) Three AA primary (1.5V) batteries in series would need to supply the micro and servo. Alternate: four AA rechargeable (1.2V) batteries with a 1N400x diode in series could also work.
by Jeff Child
