SMPS output low... 6.62 volts instead of 20 volts.
ilfish
Joined Jun 10, 2024
32
Pls. Help
No shorted components no dried up caps.
Uc2844 not shorted...
seanstevens
Joined Sep 22, 2009
323
As Ian0 is pointing out, check the feedback loop. 2.5V is generally the 'stop' command for the chip, it needs to be below that for the converter work.
ilfish
Joined Jun 10, 2024
32
Where does the Vfb signal come from? Is it from a two-resistor potential divider from the output, or via an opto-isolator?
Thanks for Swift response
Problem is this smps is not stand alone. it's within an industrial 3 phase inverter all components smd. Difficult to perform whatever you recommended me.
There are no any optocouplers at all.
The output of the schottkey diode is directly tied to 269-5g regular.
Ian0
Joined Aug 7, 2020
13,131
Can’t help any further.
if there is 2.5V at Vfb, then there is no fault in the UC3842.
