Note: I'm not an electrical engineer.
I've been researching this topic and have not seen anything that seems definitive or consistent. Working on an arcade game with an older crt-type monitor. The monitor will get faint interference lines (sometimes called "herringbone" or mori lines), which seems to come from a ground loop.
If I disconnect the earth ground of the monitor (ground wire connected directly to the monitor chassis to the third ground plug on the AC plug), the interference goes away.
I've read that tying the GND and FG on the power supply (see below that came from a Midway manual) is a way to rectify this issue as well. But have not found a good explanation on why this works, if this is safe, or some will say it will destroy the equipment.
Any help or references would be greatly appreciated! Really would like to understand this.
![1687466751121.png 1687466751121.png](https://forum.allaboutcircuits.com/data/attachments/284/284541-ef37d06ab345e117ac31048f13248188.jpg)
