Small thin on/off/on switch
winterelf
Joined Aug 3, 2017
hi,
I am building a small project which have the ability to power on using a built in battery, or using a micro-usb, for this toggle purpose I need a 3 states switch - on/off/on. I have found the following switch which has exactly the features that I need:
the problem is, it is very big, and thick. so I looked over the internet and found this mosfet swtich:
http://www.ebay.com/itm/4-5-40V-DC-...300411?hash=item1c8c80437b:g:0qoAAOSwBlNZd2nW
in terms of size, it's what I need, because it's thin, and can be mount to flat surface using screws, but it doesn't have on/off/on feautre, does anyone know about this kind of switch which gives on/off/on ability which is small and thin and can woirk at 5v with 3amp?
mtonge
Joined Apr 19, 2016
93
Your current requirement is really high for a small form, slide switch. Are you sure that you need to shove 3A through the switch? The two most common parts houses are Mouser and Digikey. Try searching for SP3T, on-off-on switches.
Reloadron
Joined Jan 15, 2015
7,889
USB A and B standard connectors have a maximum current rating of 2.0 Amps. Pretty sure a Micro-USB connector will have less capability. Companies like Cherry and Carling make miniature toggle switches and as mentioned can be found at most distributors. "Small and Thin" really doesn't give much to work with as my small and thin may not be your small and thin. Actual dimensions would help considerably.
Ron
winterelf
Joined Aug 3, 2017
Ron
well, I understand, but "small and thin" is something like the dimensions of the board switch in the ebay link above, it is perfect, and also provide enough ams. BTW, I have power bank charger which provide 2.4 amps, and I will probably need 2.4 amps max. not 3 :/
winterelf
Joined Aug 3, 2017
i need maximum of 2.4, and the project is small in space, but it is not very small in size :) it's about 140/140/70 box, and i do not have the room for a toggle switch, only a board like slide switch (for example the MOSFET Slide Switch which is used in this kind of projects that have space issues. the mosfet slide switch can give 8ams, so it's fine, but, it has only on/off, if I could find exactly the same MOSFET slide switch but with ON/OFF/ON it would be prefect :/
mtonge
Joined Apr 19, 2016
93
I think (I'm probably wrong) that the slider switch on the example board turns the power MOSFETs on and off, and they can handle up to 8amps. I don't think the switch is able to handle that kind of current without arcing and dying. I'm probably wrong.:confused:
winterelf
Joined Aug 3, 2017
I was wandering if I can use a 50v 0.5A with 5v 2.4A, I mean, if I calculate it, then it means I can, but is it strate forward? if they say 50v and 0.5A is it safe to say the proportonaly using 5v will give me anough ams? or do I missing some other things which are not taken into account.?
