Fair enough. To me the photo was ambiguous but I guess I'm the only one. Carry on.its DEFINITELY GREY.
the color im concerned with is the "violet" im not sure if its "violet or "blue"Fair enough. To me the photo was ambiguous but I guess I'm the only one. Carry on.
doesnt matter just put in any decent part of that kind?How about it F-word doesnt matter just put in any decent part of that kind? You waste time. Thats what I would tell you if you are on a job.
I dont say you have it but autistic people insist on irrelevant details and they are rude and aggressive too for no reason. As well they dont listen if you tell them things.
yup. it very likely makes no difference. when you repair a thing like this you have to understand what the part does (I do actually), if not, you are not able to understand advice.doesnt matter just put in any decent part of that kind?
great advice.
You missed the part about, "This is a photo my friend sent me. I don't have the part available to measure".Unsolder it and measure the inductance.
yeah i dont actually have it. when i discovered it...it was broken in two peices and burned. i got the picture from a friend who had the same keyboard and took a picture of the part that was burned.Unsolder it and measure the inductance.
ah great. Sorry if I offended you. But the other end must go somewhere? How about poking a wire through it + make a photo from it. If it is too difficult to search yourself where it goes.
do you have a link to a suitable product?its a multilayer. on the top side (3 holes) it goes into another layer (very likely a power supply layer).
On the other side it does connect to the left side capacitor.
My guess is the local supply for the FDC is filtered through the inductor.
it is too large and has too high DCR, or the FDC is damaged too.
There is no other purpose I can think of that makes sense.
8.2mH should be fine but I'd use a small potcore (they have much thicker wire).
Panasonic makes them. you can try but chances are the chip isnt OK too.
You can try with the floppy pulled off, and measure the current the chip takes, if any,
with a new inductor.
Value doesnt really matter much.
So this is my opinion.
I think takao21203 said it well. Throw another equivalent inductor in there, and see what happens. If the inductor pops, then you know it's UPD72069.chances are if it has just burned out, something else is damaged too.
I'd really just try 8200uH or 4700uH, guess maybe it is used as a filter coil.
RF inductors with 8200uH have a fairly high Dc resistance actually.
They are not easy to buy as single piece. I have some here actually, 8.2mH and 10mH, both small potcores.do you have a link to a suitable product?
