Single Supply Op Amps
Mick84
Joined Feb 8, 2015
12
Hello
I've hit a stumbling block with this A weighting circuit needing +/-15ac for powering the op amps.
No good to me with a portable 5v dc Arduino supply and not much 'headroom'.
I have found Single Supply Op Amps (SSM2135 @£5 a pop) I am wanting to use in place of the dual supply op amps shown.
Do you think it will work in it's current design?
What changes am I likely gonna have to make?
I will attach the OpAmp datasheets for reference.
Regards,
Mick
bertus
Joined Apr 5, 2008
22,928
That circuit is to be used on dual powersupply, as there is a ground reference.
If you want to use it on single powersupply, you will need to create a virtual ground.
Just have a look at fig37 of the smm datasheet.
DickCappels
Joined Aug 21, 2008
10,661
Incidentally, the only difference between a single supply opamp and most other opamps is that they are referred to as "single supply", usually because both their inputs and outputs can work pretty close to the supply rails. No need to spend £5 on an opamp unless you are looking for some expensive performance (noise, slew rate, etc.).
Some inexpensive opamps you might consider include the LM324/LM358 (TI old but still good for some things), LMR321G (Rohm), LMV321 (ST Microelectronics), NJU7051 (New Japan Radio Company), TLC27L2 (TI), TLC2272 (TI), TLC272CP (TI), TLC2201 (TI), TLV2771 (TI).
